Arcade script not calculating properly
629
04-01-2026 05:57 AM
JustinBernard1886
Hello,
I have a bit of a conundrum.
I have a simple arcade script that returns a calculation based on a value. When I entered "ABT", the script makes the correct calculation, but when I enter "Park" or "Street", the script returns "750"
Any reason why the else if function wouldnt work?
Here is the script
var SpacTypeClass = $feature.SpactypeCLASS;
var API = ($feature.Appraised_Trunk_Increase)
if (SpacTypeClass == 'ABT') {
    return ((API * 6.51) + 5000);
} else if (SpacTypeClass == 'Street') {
    return ((API * 6.51) + 750);
} else if (SpacTypeClass == 'Park') {
Justin
JustinBernard1886
Hey guys,
Thanks for all the help. It hit me, that the issue was the order of the attributes rules. I needed to rearrange them so the API rule calculated first. Before it was calculating AFTER the rule I posted, so it was returning zero. I reordered the rules and I am now getting the correct result.
Thanks for the help!
AlfredBaldenweck
MVP Frequent Contributor
It worked for me? Best guess is you just don't have any values in the API field for the other two, or the value is 0.
Neal_t_k
MVP Regular Contributor
Have you considered a When statement instead of the nested if else?
something like:
var spClass =
  When(
    SpacTypeClass == 'ABT', 5000,
    SpacTypeClass == 'Street', 750,
    SpacTypeClass == 'Park', 750,
return (API * 6.51) + spClass;
Also if it is just returning  "750" for Street and Park, your calc may be working but API is returning 0 for those cases.  Double check that an API exists for those.
JustinBernard1886
Hey guys,
