Arcade Script For Converting From State Plane to Decimal Degrees
3300
7
01-30-2025 02:30 PM
Labels (2)
RPGIS
by MVP Regular Contributor
I found this code that I copied from copilot and modified for my specific needs and works somewhat but needs some major corrections.
// Constants for NAD83 Georgia West (FIPS 1002)
var A = 6378137.0; // Semi-major axis for NAD83
var F = 1 / 298.257222101; // Flattening for NAD83
var E2 = (2 * F) - (F * F); // Eccentricity squared
var centralMeridian = -84.16666666666667 * (PI / 180); // Central meridian for Georgia West (degrees to radians)
var latitudeOfOrigin = 30.0 // Latitude of origin (degrees to radians)
var scaleFactor = 0.9999; // Scale factor
var falseEasting = 2296583.333333 * 0.3048006096012192; // False easting in meters (1 US foot = 0.3048006096012192 meters)
var falseNorthing = 0.0; // False northing in meters
// Function to convert State Plane (NAD83) to Latitude and Longitude
function statePlaneToLatLong(x, y) {
    x *= 0.3048006096012192; // Convert x from US Feet to meters
    y *= 0.3048006096012192; // Convert y from US Feet to meters
    x -= falseEasting;
    y -= falseNorthing;
    var m = y / scaleFactor;
    var mu = m / (A * (1 - (E2 / 4) - (3 * E2 * E2 / 64) - (5 * E2 * E2 * E2 / 256)));
    var e1 = (1 - sqrt(1 - E2)) / (1 + sqrt(1 - E2));
    var phi1 = mu + (3 * e1 / 2 - 27 * pow(e1, 3) / 32) * sin(2 * mu)
        + (21 * pow(e1, 2) / 16 - 55 * pow(e1, 4) / 32) * sin(4 * mu)
        + (151 * pow(e1, 3) / 96) * sin(6 * mu)
        + (1097 * pow(e1, 4) / 512) * sin(8 * mu);
    var sinPhi1 = sin(phi1);
    var cosPhi1 = cos(phi1);
    var t1 = tan(phi1) * tan(phi1);
    var c1 = E2 * cosPhi1 * cosPhi1 / (1 - E2);
    var r1 = A * (1 - E2) / pow(1 - E2 * sinPhi1 * sinPhi1, 1.5);
    var n1 = A / sqrt(1 - E2 * sinPhi1 * sinPhi1);
    var d = x / (n1 * scaleFactor);
    // Calculate latitude and longitude in radians
    var latitude = phi1 - (n1 * tan(phi1) / r1)
        * (d * d / 2 - (5 + 3 * t1 + 10 * c1 - 4 * c1 * c1 - 9 * E2) * pow(d, 4) / 24
        + (61 + 90 * t1 + 298 * c1 + 45 * t1 * t1 - 252 * E2 - 3 * c1 * c1) * pow(d, 6) / 720);
    var longitude = centralMeridian + (d - (1 + 2 * t1 + c1) * pow(d, 3) / 6
        + (5 - 2 * c1 + 28 * t1 - 3 * c1 * c1 + 8 * E2 + 24 * t1 * t1) * pow(d, 5) / 120) / cosPhi1;
    // Convert latitude and longitude to degrees
    var latitudeDeg = latitude * (180 / PI)*10;
    var longitudeDeg = longitude * (180 / PI);
    // Format results as degrees North and degrees West
    return {
        latitude: round( abs(latitudeDeg) , 6),
        longitude: round( abs(longitudeDeg) , 6)
// Example usage with provided coordinates
var x = Geometry($feature).x; // X coordinate in US feet
var y = Geometry($feature).y; // Y coordinate in US feet
var result = statePlaneToLatLong(x, y);
console(result); // Output: {latitude: "xy.xyzxyz° N", longitude: "xy.xyzxyz° W"}
return result.latitude
LindsayRaabe_FPCWA
Can I suggest adding the purpose of the code to the post heading to make it more searchable? I believe it's a Lat/Long conversion code, which I know a lot of people would be looking for. Also maybe add some tags to improve search results.
Lindsay Raabe
GIS Officer
Forest Products Commission WA
RPGIS
Thanks @LindsayRaabe_FPCWA for the suggestion. I went ahead and made the changes, and I am hoping that this can be used to create a function for attribute rules. I think there might be something simpler than this, but I will need to explore further.
DavidColey
MVP Frequent Contributor
Hello @RPGIS  - would you be able to share how you used copilot to derive your expression?  I ask because when I try to parametrize for Florida State Plane West HARN, the only differences are the centralMeridian, latitutudeOfOrigin and the scale factor.
var centralMeridian = -82.0 * (PI / 180); // Central meridian for NAD83 HARN Florida State Plane West (degrees to radians)
var latitudeOfOrigin = 24.33333333333333 // Latitude of origin (degrees to radians)
var scaleFactor = 0.9999411764705882; // Scale factor
Other than the scale factor for HARN carrying more precision than the NAD 83 above I cannot seem to find where HARN would cause my conversions to have a 0.1 degree shift north in latitude and 0.05 shift east in longitude.
For example, when I plug in the expressions for my respective lat and lon attributes:
Pro: 27.078110470, -82.43048022
Arcade: 27.505790, -82.383999
Its interesting too because the console returns different values from the actual calculation:
{"latitude":27.851679,"longitude":-82.409632}
Any insights you can provide are appreciated, (I just don't have the trig to keep up) -
David
Link to a similar post with an Arcade expression that works for State Plane North / South coordinate systems (Lambert Conformal Conic)
https://community.esri.com/t5/arcgis-pro-ideas/arcade-projectas-geometry-function/idi-p/1171382/page...
@TomNeer
RPGIS
I noticed that there some issues with the console values as well that I am trying to breakdown the math but this code was copied, like you said, using copilot but it is incorrect.
When I ran some tests it worked in some instances and not in others. I also noticed that sometimes it would be off by 4 degrees in some spots but I am trying to figure out where that issue is in the code.
MDB_GIS
There are a few issues that I've noticed. I actually just created basically the exact same version of this script using another geonet users post as a starting point, only their data was in Colorado state plane west. But I've managed to get it to work for Georgia. Here are the issues that I've noticed:
 1. Your latitude of origin is unused. It is needed to calculate the correct meridian arc.
//unused
2. Unless I'm missing something, you are multiplying your latitude by 10 for no reason which would just make your latitude 10 times too large in every scenario.
3. You convert x,y to meters first, and then subtract the false easting, which was already converted to meters. It's a bit cleaner and easier to keep them in ft-us and then convert to meters at the end like so:
var ft_to_m = 0.3048006096012192;                 // US survey foot -> metervar E_m = (E - falseE_ft) * ft_to_m;
var N_m = (N - falseN_ft) * ft_to_m;
Here is my version which works for Georgia state plane west. Let me know if you have any questions.
// Inverse Transverse Mercator for EPSG:2240 (NAD83 / Georgia West (ftUS))
// Returns latitude, longitude in decimal degrees
// Input projected coordinates (assumes geometry is in EPSG:2240)
var E = Geometry($feature).x; // Easting (ftUS)
var N = Geometry($feature).y; // Northing (ftUS)
// Projection parameters from EPSG:2240
var a = 6378137.0;                                // semimajor axis (meters)
var inv_f = 298.257222101;                        // inverse flattening
var f = 1 / inv_f;
var e2 = 2 * f - f * f;                           // eccentricity squared
var k0 = 0.9999;                                  // scale factor
var lon0 = -84.1666666666667;                     // central meridian (deg)
var lat0 = 30.0;                                  // latitude of origin (deg)
var falseE_ft = 2296583.333;                      // false easting (ftUS)
var falseN_ft = 0.0;                              // false northing (ftUS)
// helpers
function degToRad(d) { return d * PI / 180.0; }
function radToDeg(r) { return r * 180.0 / PI; }
// convert inputs into meters and remove false easting/northing
// --- compute meridian arc for latitude of origin (M0) ---
function meridianArc(phi) {
  // phi in radians
  var n2 = e2;
  var a0 = 1 - (n2/4) - (3*Pow(n2,2)/64) - (5*Pow(n2,3)/256);
  var a2 = (3.0/8.0) * (n2 + (Pow(n2,2)/4) + (15*Pow(n2,3)/128));
  var a4 = (15.0/256.0) * (Pow(n2,2) + (3*Pow(n2,3)/4));
  var a6 = (35.0/3072.0) * Pow(n2,3);
  return a * (a0 * phi - a2 * Sin(2*phi) + a4 * Sin(4*phi) - a6 * Sin(6*phi));
var lat0R = degToRad(lat0);
var M0 = meridianArc(lat0R);
// --- compute M (meridian arc to footpoint) from N_m ---
var M = M0 + (N_m / k0);
// --- Compute footpoint latitude (phi1) from M using series ---
var mu = M / (a * (1 - e2/4 - 3*Pow(e2,2)/64 - 5*Pow(e2,3)/256));
// e1 (called e' or e1 in many references)
var e1 = (1.0 - Sqrt(1.0 - e2)) / (1.0 + Sqrt(1.0 - e2));
// series coefficients for footpoint latitude
var J1 = (3*e1/2) - (27*Pow(e1,3)/32);
var J2 = (21*Pow(e1,2)/16) - (55*Pow(e1,4)/32);
var J3 = (151*Pow(e1,3)/96);
var J4 = (1097*Pow(e1,4)/512);
var phi1 = mu + J1 * Sin(2*mu) + J2 * Sin(4*mu) + J3 * Sin(6*mu) + J4 * Sin(8*mu);
// --- compute parameters at phi1 ---
var sin1 = Sin(phi1);
var cos1 = Cos(phi1);
var tan1 = Tan(phi1);
var N1 = a / Sqrt(1 - e2 * Pow(sin1,2));                   // radius of curvature in prime vertical
var R1 = a * (1 - e2) / Pow(1 - e2 * Pow(sin1,2), 1.5);    // meridional radius of curvature
var T1 = Pow(tan1,2);
var C1 = (e2 / (1 - e2)) * Pow(cos1,2);                    // e'² * cos²(phi1)
var D = E_m / (N1 * k0);
// --- Series expansion to get latitude (phi) ---
var term1 = (D*D / 2.0);
var term2 = (5 + 3*T1 + 10*C1 - 4*Pow(C1,2) - 9*(e2/(1-e2))) * Pow(D,4) / 24.0;
var term3 = (61 + 90*T1 + 298*C1 + 45*Pow(T1,2) - 252*(e2/(1-e2)) - 3*Pow(C1,2)) * Pow(D,6) / 720.0;
var phi = phi1 - (N1 * tan1 / R1) * (term1 - term2 + term3);
// --- Series expansion to get longitude ---
var lon_term1 = D;
var lon_term2 = (1 + 2*T1 + C1) * Pow(D,3) / 6.0;
var lon_term3 = (5 - 2*C1 + 28*T1 - 3*Pow(C1,2) + 8*(e2/(1-e2)) + 24*Pow(T1,2)) * Pow(D,5) / 120.0;
var lon = degToRad(lon0) + (lon_term1 - lon_term2 + lon_term3) / cos1;
// convert to decimal degrees
var lat_dd = radToDeg(phi);
var lon_dd = radToDeg(lon);
// change me
return lat_dd
RPGIS
Thank you very much @MDB_GIS,
I will be sure to test this out and see how this works to align with our CAD coordinate system since that has been somewhat of a boondoggle.
MDB_GIS
Great! Let me know how it goes!
