Secure Storage in Stackview
2979
8
11-13-2018 10:18 AM
GiatriLalla
Good Day,
How can I retrieve a value and/ a key on Page 1 for instance, if it was stored using secure storage on the Startpage of a stackview layout. I have tried the value method however I am not successful. For example:
1. Start Page would look something like
TextField {
   placeholderText: "Enter key"
TextField {
   placeholderText: "Enter value"
   anchors.left: key.right
//Click on the button to store data into keychain
Button {
   text: qsTr ("Secure Data")
   anchors.left: key.bottom
   onClicked: {
         SecureStorage.setValue(key.text, value.text)
2. Page 1 would look something like
//Click on button to retrieve data
Button {
   text: qsTr ("Retrieve Data")
   anchors.top: secureButton.bottom
   onClicked: {
         retrieveData.text = qsTr("Value:") + SecureStorage.value(key.text)
//Display retrieved data
Text {
   anchors.top: retrieveButoon.bottom
The information is being stored however I can not retrieve the information.
JaysonWard
I think the issue is that the key and value components with their associated properties aren't available to the Page 1 view in the stack since they are defined in Start Page and aren't global or passed to Page 1.
ErwinSoekianto
Esri Alum
Giatri,
That should work, what is the error message? Did you make sure to have the import statement in the other page?
Please refer to this documentation page for Secure Storage and sample page
Thank you,
Erwin.
JaysonWard
GiatriLalla
Good Morning,
How can I rectify this? Thank you.
JaysonWard
Hi Giatri:
I'm not sure if there are security implications to these but you would need to either:
  1. Create a string property on the App component and assign the key.value to it at the same time you set the SecureStorage.value. Then you can reference that 'global' string property in Page 1, or
  2. Create a string property on each view, assign the key.value to the property in StartPage, then when you push Page1 onto the stack, assign the string property in Page 1 to the string property value on Start Page
So Number 1 above would look something like this:
App {
width: 400
height: 750
property string secureStorageKeyValue: ""
Button {
   onClicked: {
         app.secureStorageKeyValue = key.text;
         SecureStorage.setValue(key.text, value.text);
Page 1
Button {
   onClicked: {
         retrieveData.text = qsTr("Value:") + SecureStorage.value(app.secureStorageKeyValue);
Number 2
StartPage {
Button {
   onClicked: {
         startPage.secureStorageKeyValue = key.text;
yourStackView.push( pageOneViewId, { "secureStorageKeyValue": startPage.secureStorageKeyValue } );
PageOne {
Button {
   onClicked: {
         retrieveData.text = qsTr("Value:") + SecureStorage.value(secureStorageKeyValue);
GiatriLalla
I had a chance to try both. I don't think any work for me. The second option gave alot of errors and the first is giving me the results as seen in the picture. I dont not know how to proceed. For privacy reasons, I do not want to share my code on here but if I can get that to you, maybe you'd be able to see the results yourself. Please advise accordingly. Thank you in advance.
ErwinSoekianto
Esri Alum
I would recommend working with Esri Technical Support‌ for further troubleshooting.
GiatriLalla
I do not get any response from Esri Technical Support when I post a question.
ErwinSoekianto
Esri Alum
Our apologies, what I was trying to say is, you should contact Esri Technical Support, Esri Support Contact Support , via phone call, email or chat.
