Qml ServiceFeatureTable : Credential token not working
1076
08-13-2018 02:15 AM
KeithMartyn
I am using AppStudio to build an application that uses secured feature services. I declared a Feature Layer and a ServiceFeatureTable as shown below. I am passing the token in the credential.token property. The features donot show up on the map. If I paste the feature layer url followed by the token in a browser, I can see the feature layer details. What am I doing wrong in the example shown below
import QtQuick 2.7
import QtQuick.Controls 2.1
import QtQuick.Controls.Styles 1.4
import QtQuick.Controls.Material 2.1
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Controls 1.0
import Esri.ArcGISRuntime 100.1
Item {
    property real scaleFactor: AppFramework.displayScaleFactor
    // Map view UI presentation at top
    MapView {
        anchors.fill: parent
        Credential {
            token : "dhCmM1r-nHjlh6-d-EeMlUqiGVlOIL91NoVRF6eIQO9oXEoL7X2IJ0riZBMMlOQPcZbOP4pmkdGwoL96grvcZ5pfS1BXcFJjReuNYYCyG0qF0FfpfueRRK8jSvoDz0UbDa7nb48-czOdg8fyqKaE0a6hFm_RFhlxphfDV7ldKbBWQTN9R0Zhnct-6Trqnzx6WnFv_fv8QbSLTaZc7IDaTTJWFPMBt8RS8HIlQivAKKInws7ZF-ZMxNvZ6l9NFJo3xv38arV51LJkfMcHcA137Q.."
        //! [Display Feature Service]
        Map {
            BasemapTerrainWithLabels {}
            initialViewpoint: vc
            FeatureLayer {
                popupEnabled: true
                PopupDefinition {
                    fields: featureTable.fields
                ServiceFeatureTable {
                    url: "https://services9.arcgis.com/w5LjzOecXeZ5ftNR/arcgis/rest/services/Storm_Inlet/FeatureServer/0"
                    credential : cred
        ViewpointCenter {
            center: Point {
                x: -13176752
                y: 4090404
                spatialReference: SpatialReference {
                    wkid: 102100
            targetScale: 300000
        // Busy Indicator
        BusyIndicator {
            anchors.centerIn: parent
            height: 48 * scaleFactor
            width: height
            running: true
            Material.accent:"#8f499c"
            visible: (mv.drawStatus === Enums.DrawStatusInProgress)
nakulmanocha
Instead of Token, can you use username and password.
Credential QML Type | ArcGIS for Developers
If you wanna avoid username and password. You could do that using oAuthClientInfo by using clientId and clientSecret approach
OAuthClientInfo QML Type | ArcGIS for Developers
Nakul
