Mobile.Geodatabase Table as a featureTable for FeatureFenceParameters
1264
06-15-2022 12:19 AM
ECarson
Hi All,
I'm trying to make a FeatureFenceParameters from a Mobile.Geodatabase for a Geotrigger. Everything loads however the trigger does not work as expected. Everything works fine if the featureTable for  FeatureFenceParameters is built from a ServiceFeatureTable.
I'm unsure how to correctly initiate a FeatureLayer from a Mobile.Geodatabase that will work for  FeatureFenceParameters featureTable?
Any help is appreciated.
//FeatureLayer {
// ServiceFeatureTable {
// id: fT
// url: "https://..."
// definitionExpression: "STATUS IN ('Exists')"
FeatureLayer {
featureTable: gdb.geodatabaseFeatureTablesByTableName["ThisTable"] ? gdb.geodatabaseFeatureTablesByTableName["ThisTable"] : null
FeatureFenceParameters {
featureTable: fT.featureTable
//featureTable: fT ---- Error: Unable to assign QmlFeatureLayer to QmlFeatureTable
//featureTable: gdb.geodatabaseFeatureTablesByTableName["ThisTable"] ? gdb.geodatabaseFeatureTablesByTableName["ThisTable"] : null ---- Does not produce anything
bufferDistance: 50
GeotriggerMonitor {
geotrigger: FenceGeotrigger{
feed: LocationGeotriggerFeed {
locationDataSource: simulatedLocationdataSource
ruleType: Enums.FenceRuleTypeEnterOrExit
fenceParameters: fFP
// Handle notification events
onGeotriggerNotification: {
if (geotriggerNotificationInfo.fenceNotificationType === Enums.FenceNotificationTypeEntered) {
entry();
} else{
exit();
Component.onCompleted: {
// Start monitoring Geotrigger event.
console.log("GeotriggerMonitor: Start monitoring!");
geotriggerMonitor.start();
TrevorFrame
Hi @ECarson,
In your GeotriggerMonitor{}, add an onWarningChanged signal handler to console any warnings. These warnings are pretty descriptive and helped me setup a Geotrigger Monitor with the Feature Layer (Geodatabase) sample we have. You can setup something like:
onWarningChanged: {
     console.log(`Status code: ${status}... Warning message: ${warning.additionalMessage}`)
Using this, I found the featureTable the geotrigger monitor is monitoring isn't valid at time of start. What I ended up doing was creating a global property to track the geodatabase feature table.
property var geoDb: null
In the Geodatabase component, I setup a the onGeodatabaseFeatureTablesChanged signal handler to set the geodatabase feature table property and started the simulatedLocationdataSource and geotrigger monitor. I did this to ensure the feature table is retrieved before starting the geotrigger monitor.
Geodatabase {
     path: AppFramework.resolvedPathUrl(copyLocalData(inputGDB, outputGDB))
     onGeodatabaseFeatureTablesChanged: {
          geoDb = geodatabaseFeatureTables[0]
          simulatedLocationdataSource.start()
          geoTrigger.start()
Best,
Trevor
TrevorFrame
Hi @ECarson,
onWarningChanged: {
Geodatabase {
          geoTrigger.start()
Best,
Trevor
ECarson
Thanks for the the reply Trevor, this certainly worked.
I wasn't able to figure out how to apply a definition expression on the feature table before applying it to the FeatureFenceParamters or apply a whereclause within. I just had a feature table in the mobile geodatabase with only the features I wanted.
If anyone has a an idea about this additional solution it would be great.
Regards,
Elliott
