MMPK Storage
4976
22
05-08-2019 05:49 AM
jaykapalczynski
Honored Contributor
Can I install the app on my phone but store the .mmpk files on the external storage card?  If so how do I point to this new location?
jaykapalczynski
Honored Contributor
I am using the Quick Report template....maybe there is a setting in the QuickReportApp.qml file?
ErwinSoekianto
Esri Alum
There is no setting the in the Quick Report template to change the default storage location of the mmpk file, but this can be change in the code in QuickReport/controls/MmpkManager.qml ~80
Thank you,
Erwin
jaykapalczynski
Honored Contributor
Perfect thanks....will give that a whirl....appreciated.
jaykapalczynski
Honored Contributor
So if I am correct I think this is the line that I need to modify
var path = [fileFolder.path, "~"+itemName].join("/");
jaykapalczynski
Honored Contributor
In the MmpkManager.qml file
I added line 13
commented line 15
added/modified line 16
I uploaded and did a make on the project....I downloaded and installed from AGOL and when I went offline it still saved the download to the Phone itself and not the SD Card:
SAMSUNG-SM-J727V\Phone\ArcGIS\AppStudio\Data\QuickReport
Am I missing something?
            onReadyStateChanged: {
                if (readyState === NetworkRequest.DONE ){
                    if(errorCode != 0){
                        loadStatus = 2;
                    } else {
                        var root = JSON.parse(responseText);
                        if(root.type == "Mobile Map Package"){
                            loadStatus = 1;
                            var component = networkRequestComponent;
                            var networkRequest = component.createObject(parent);
                            var url = rootUrl+itemId+"/data";
                            var fileslocation = "/mnt/sdcard/ArcGIS/AppStudio/Data/QuickReport/"
                            //var path = [fileFolder.path, "~"+itemName].join("/");
                            var path = [fileslocation, "~"+itemName].join("/");
                            networkRequest.downloadFile("~"+itemName, url, path, typeNetworkRequest.callback);
                        } else {
                            loadStatus = 2;
jaykapalczynski
Honored Contributor
Can I change the code in this location at the top of the MmpkManager.qml ????
    FileFolder{
        //readonly property url storageBasePath: AppFramework.userHomeFolder.fileUrl("ArcGIS/AppStudio/Data")
        readonly property url storageBasePath: "/mnt/sdcard/ext_sd/ArcGIS/AppStudio/Data"
        property url storagePath: subFolder && subFolder>"" ? storageBasePath + "/" + subFolder : storageBasePath
        url: storagePath
        Component.onCompleted: {
            if(!fileFolder.exists){
                fileFolder.makeFolder(storagePath);
            if(!fileFolder.fileExists(".nomedia") && Qt.platform.os === "android"){
                fileFolder.writeFile(".nomedia", "");
jaykapalczynski
Honored Contributor
Has anyone done this before.....I got this to work when I changed it to the C:/Temp/Test on my PC....but still cant get it to my phone storage card.  The below first two examples show how I did this to my C Drive.
In the MmpkManager.qml file at the bottom if I change the readonly property url to the below nothing happens...
                    if(errorCode != 0){
                        loadStatus = 2;
                    } else {
                            loadStatus = 1;
                   // ADDED
                            var fileslocation = "C:/Temp/tEST/QuickReport"
                   // COMMENTED OUT
                   // MODIFIED THE ABOVE TO THIS
                        } else {
                            loadStatus = 2;
If I then go to the top of the MmpkManager.qml file and change the below it no uses the C drive and shows the mmpk file through AppStudio when I run the project.
I have to make both changes to get it to work
    FileFolder{
    // COMMENTED OUT
    // MODIFIED TO THIS
        // THIS WORKS ON THE DESKTOP
        readonly property url storageBasePath: "C:/Temp/tEST"
        url: storagePath
If I make the two above changes it works....I am then trying to modify that so I can use on my Phones SD Card and nothing works....
My question is am on on the right path?  Are there any other modifications that I need to make to the code to get this to work?
I then try this...to get to the storage card
At the top of the MmpkManager.qml
readonly property url storageBasePath: "/storage/Test"‍‍
At the bottom of the MmpkManager.qml
var fileslocation = "/storage/Test/QuickReport"
Any one have any thoughts?
ErwinSoekianto
Esri Alum
Jay,
The path to external storage card on every device and platform can be varied.
The best way to get the path to the external storage card (if present, I am assuming Android?) is by using the StorageInfo plugin from AppStudio AppFramework.
For example like this,
    StorageInfo {
        var path, fs, dev;
        var mountedVols = storageInfo.mountedVolumes;
        for (var i = 0; i < mountedVols.length; i++) {
            fs = mountedVols[i].fileSystemType;
            console.log("file system type: ", fs);
            dev = mountedVols[i].device
            console.log("device: ", dev);
            path = mountedVols[i].path;
            console.log("path: ", path);
The path to the storage card normally starts with "/storage/..." or "/mnt/...
Thank you,
Erwin
jaykapalczynski
Honored Contributor
Fantastic...this uncovered I had the path incorrect the whole time....going to give this a shot....
THANKS
