Issue debugging Survey 123 Connect (Template) in QT Creator
6036
11
09-12-2018 10:59 AM
LyndaMcCallum1
Hi
I've followed the steps outlined here to debug the template in QT Creator (Community Edition)
Debug JavaScript in Qt Creator—AppStudio for ArcGIS | ArcGIS
When trying to run the debug on the out of the box survey 123 template, I get the following errors from Qt Creator
13:58:21: Debugging starts
13:58:21: Starting C:\Qt\5.10.0\msvc2017_64\bin\qmlscene.exe C:/Users/myuser/ArcGIS/AppStudio/Apps/7d2b8e83c9e44cd4b9e511757e9849d5/Survey123Connect.qml "-qmljsdebugger=port:51225,block,services:DebugMessages,QmlDebugger,V8Debugger,QmlInspector"
QML Debugger: Waiting for connection on port 51225...
ArcGIS.AppFramework.Plugin: void __cdecl AppFrameworkPlugin::registerTypes(const char *) ArcGIS.AppFramework
ArcGIS.AppFramework.Plugin: void __cdecl AppFrameworkPlugin::initializeEngine(class QQmlEngine *,const char *) ArcGIS.AppFramework
ArcGIS.AppFramework.Plugin: void __cdecl AppFrameworkPlugin::initializeEngine(class QQmlEngine *,const char *) Offline storage path: "C:\\Users\\myuser\AppData\\Local\\QtProject\\QtQmlViewer\\QML\\OfflineStorage"
ArcGIS.AppFramework.Plugin: void __cdecl AppFrameworkPlugin::initializeEngine(class QQmlEngine *,const char *) CoInitializeEx failed: -2147417850
ArcGIS.AppFramework.Plugin: void __cdecl AppFrameworkPlugin::initializeNetwork(void) Using system network proxy configuration
ArcGIS.AppFramework.Image: void __cdecl ImageProvider::initialize(class QQmlEngine *) QQmlEngine(0x79b7aff0f8)
ArcGIS.AppFramework.Image: __cdecl ImageProvider::ImageProvider(class QFlags<enum QQmlImageProviderBase::Flag>) QFlags()
Registering QML types: ArcGIS.AppFramework.Desktop
Initializing QML engine: ArcGIS.AppFramework.Desktop
ArcGIS.AppFramework.Sql.Projection: void __cdecl Proj4::initialize(void) PJ_VERSION: 493
ArcGIS.AppFramework.Sql.ST: class QString __cdecl ST_Projection::lookupDef(int) 4326 = "+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
file:///C:/Users/myuserArcGIS/AppStudio/Apps/7d2b8e83c9e44cd4b9e511757e9849d5/Survey123Connect.qml:1... Type ConnectApp unavailable
file:///C:/Users/myuser/ArcGIS/AppStudio/Apps/7d2b8e83c9e44cd4b9e511757e9849d5/Connect/ConnectApp.qml:214 Type TutorialsTab unavailable
file:///C:/Users/myuser/ArcGIS/AppStudio/Apps/7d2b8e83c9e44cd4b9e511757e9849d5/Connect/TutorialsTab.... plugin cannot be loaded for module "QtWebView": Cannot load library C:\Qt\5.10.0\msvc2017_64\qml\QtWebView\declarative_webview.dll: Th
e specified module could not be found.
13:58:23: Debugging has finished
13:52:41: Debugging has finished
ShobanaSuresh
Hi Lynda,
As mentioned by John, Survey123 Connect will work only on Windows, macOS and Linux desktop platforms. It's not designed to run on Android device, Android emulator and iOS. That's why your custom Survey123 Connect Template app fails to load in below cases
- Android emulator using the App Studio Launch to Virtual Devices
- AppStudio Player on iPhone
Only the apps that can run on an Android device can be tested in Android emulator using AppStudio Launch to Virtual Devices feature.
To test your survey on Android emulator / iPhone, you would have to create a custom Survey123 field app using the template shown in below screenshot and deploy that to Android / iPhone.
If your goal is to make changes to Survey123 to limit what surveys appear on the field app running on Android, iOS and desktop platforms, you would need to create a new app from the Survey123 (Template) instead of Survey123 Connect (Template).
Hope this helps.
Shobana
LyndaMcCallum1
Ok. I'm still getting errors with this approach as well. I will move my issue to tech support for resolution. Thanks.
