In AppStudio & ArcCollector the ability to do a multi field search
1014
02-03-2020 09:54 AM
deleted-user-aT9BCrgkP4kc
In AppStudio the ability to do a multi field search on a feature, so if you are using a point as an example, you would want to be able to search on say the color but also search on the size at the same time (similar functionality to a filter but through the search bar.
Regards,
Cody
Tags (1)
ErwinSoekianto
Esri Alum
Hello Cody,
Are you asking AppStudio to support this? are you using our MapViewer template?
Thank you,
Erwin
