Impossibility to execute VACUUM query
1794
01-28-2019 02:15 AM
José_LuisGomez
I need to perform a "VACUUM" on my app database using QtQuick.LocalStorage 2.0 or using the SqlDatabase Type but pointing the database from QtQuick.LocalStorage.
Must work on Android and iOS devices.
Any idea?
StephenQuan1
José can you tell us what you have tried?
José_LuisGomez
I tried to execute a VACUUM using LocalStorage, but is not able to run it because it must be executed from outside a transaction.
function repackingDatabase(){
    var db = LocalStorage.openDatabaseSync("BLAHBLAHBLAH_DB", "", "Local database", 1000000);
    try {
        db.transaction(function (tx) {
            tx.executeSql('VACUUM;');
    } catch (err) {
        console.exception("Error repacking the Database: " + err);
My database must sometimes handle a large amount of data.
But even if you delete those rows or even delete the tables the space occupied by the app continues to increase.
StephenQuan1
Hi José, in the following example, I'm able to use `VACUUM` on a `SqlDatabase`:
import QtQuick 2.7
import QtQuick.Controls 2.1
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Controls 1.0
import ArcGIS.AppFramework.Sql 1.0
App {
    width: 800
    height: 640
    property string dbFileName: "sample.sqlite"
    property string dbFilePath: sqlFolder.filePath(dbFileName)
    ListView {
        property ListModel logListModel: ListModel { }
        anchors.fill: parent
        anchors.margins: 10
        model: logListModel
        delegate: Text { text: logText }
        function log(logText) { logListModel.append( { logText: logText } ); }
    FileFolder {
        path: "~/ArcGIS/Data/Sql"
    SqlDatabase {
        databaseName: dbFilePath
    function db_exec_sql(sql, obj) {
        listView.log( "db_exec_sql.sql: %1".arg(sql) );
        if (obj != null) {
            listView.log( "db_exec_sql.obj: %1".arg(JSON.stringify(obj)) );
        var query = obj != null ? db.query(sql, obj) : db.query(sql);
        if (query.error) {
            listView.log( "query.error: %1".arg(query.error) );
            return;
        var ok = query.first();
        while (ok) {
            listView.log( "query.values: %1".arg(JSON.stringify(query.values)));
            ok = query.next();
        query.finish();
    Component.onCompleted: {
        listView.log( "dbFileName: %1".arg(dbFileName) );
        listView.log( "dbFilePath: %1".arg(dbFilePath) );
        sqlFolder.makeFolder();
        db.open();
        db_exec_sql( "DROP TABLE IF EXISTS people" );
        db_exec_sql( "CREATE TABLE people (NAME text)" );
        db_exec_sql( "INSERT INTO people VALUES (:name) ", { name: 'Bill Gates' } );
        db_exec_sql( "INSERT INTO people VALUES (:name) ", { name: 'Jack Dangermond' } );
        db_exec_sql( "SELECT * FROM people" );
        db_exec_sql( "VACUUM" );
The program completes successfully, and, because I use `~/ArcGIS/Data/Sql`, the folder will exist on all platforms. The output I get when I run the above on Windows is:
dbFileName: sample.sqlite
dbFilePath: C:/Users/stephen/ArcGIS/Data/Sql/sample.sqlite
db_exec_sql.sql: DROP TABLE IF EXISTS people
db_exec_sql.sql: CREATE TABLE people (NAME text)
db_exec_sql.sql: INSERT INTO people VALUES (:name)
db_exec_sql.obj: {"name":"Bill Gates"}
db_exec_sql.obj: {"name":"Jack Dangermond"}
db_exec_sql.sql: SELECT * FROM people
query.values: {"NAME":"Bill Gates"}
query.values: {"NAME":"Jack Dangermond"}
db_exec_sql.sql: VACUUM
JorgeFrade_Martínez
Hi Stephen,
I´m a workmate of Jose, he has some trouble with his account and can´t answer and has told me that send this to you.
Yeah, i know.
But i need to do the vacuum to the QtQuick.LocalStorage 2.0 database.
Its mandatory to me, due to the needs of the project, use QtQuick.LocalStorage 2.0.
