Import statement unable to load some modules
1356
12-03-2017 10:22 AM
MervynLotter
MVP Regular Contributor
Hi there
I am a newby to AppStudio and while working through the Load a Web Map and Display Device Location tutorial, I noticed that one of the modules did not import. It is the: import QtGraphicalEffects 1.0 module. See attached image'
I am running "AppStudio for ArcGIS 2.1.19"  on Windows 10. I first noticed this problem running an earlier version (2.1.15) but tried updating to see whether that would fix the problem, but did not.
I have noticed that this module has failed to import in other apps I am playing/working with.
nakulmanocha
Hi Mervyn,
Thanks for posting your issue. This is a known issue with Qt 5.8 and Qt 5.9.1. We are hoping to get this fixed with 5.10 release.
Nakul
nakulmanocha
Hi Mervyn,
Nakul
MervynLotter
Hi Nakul
Thank you for reply. Will Qt 5.10 be released with AppStudio 2.2 or earlier. Or any idea when we can expect Qt 5.10?
Regards
Mervyn
nakulmanocha
Yes we are planning to release AppStudio 2.2 with Qt 5.10. But it is early days and 5.10 is not released yet so can't be 100% sure at this time. Plus I don't know if this known issue do get resolved with the 5.10 final release.
Nakul
