Image is not storing into device.
1304
03-25-2021 05:59 AM
x_d
Hi, I tried  to download an image from server and store it locally on the first page and then on second page i tried to show that image using the local path(where the downloaded image is stored) . I tested this example on desktop and on my mobile using appstudio player. It is working fine over there but on android it is not working. the image does not get saves to the path.
Here is the First_page page1.qml
Page{
    FileInfo {
            url: "~"
//Downloads an image from the web
NetworkRequest {
    url: "http://appstudio.arcgis.com/images/index/introview.jpg"
    responsePath: destData.path +"/appstudio.jpg"
    property url imagePath: responsePath
   onReadyStateChanged: {
        if (readyState == NetworkRequest.DONE) {
    onError: {
        console.log(errorText + ", " + errorCode)
        image.source = ""
Column{
    Layout.alignment: Qt.AlignHCenter
    spacing: 70
    Layout.rightMargin: 20
    Image {
        source: "../../assets/images/btn_pre.png"
        MouseArea{
            anchors.fill: parent
            onClicked: {
                stackView.push("page2.qml");
    ColumnLayout {
        spacing: 20
        Button {
            text: "Download Request (Download Image)"
            Layout.margins: 2
            Layout.fillWidth: true
            onClicked: {
                networkRequest.send({f:"json"});
[[And Here is Second_page page2.qml]]
Page{
    Column{
        spacing: 50
    Row{
        Layout.topMargin:20
        spacing: 70
        Image {
            MouseArea{
                onClicked: {
                      stackView.pop()
    Image {
        Layout.margins: 10
        width: 200
        height: 400
        source: "appstudio.jpg"
ErwinSoekianto
Esri Alum
@x_d
Can you try this below?
On the NetworkRequest { responsePath: destData.fileUrl("appstudio.png")
And the when you access it on the Image { source: destData.fileUrl("appstudio.png")
Thank you,
Erwin
x_d
I'm getting this error,
Property 'fileUrl' of object FileInfo(0x1c95f5581b0) is not a function
