I am building a Quick Report app in AppStudio. When I update the feature layer in ArcGIS Online, the updates are not reflected in the draft app.
1024
01-23-2020 07:28 AM
DrewGaskins
I am trying to develop four interactive integer fields for a point feature in a Quick Report app. I drafted a single integer field in ArcGIS Online for testing purposes before populating the rest. This worked. Subsequent edits to that field and the addition of three additional fields are not reflected when I hit "Run" for the app in AppStudio.
ErwinSoekianto
Esri Alum
Drew,
You need to "reset" the app to get the latest changes from the feature layer fields. Side Menu > Settings > Reset.
Thank you,
Erwin
ErwinSoekianto
Esri Alum
Drew,
Thank you,
Erwin
DrewGaskins
That did it! Thanks!
