How to read parameter from a url
1074
01-12-2021 09:39 AM
x_d
I want to know how to open specific screen in my app , when some qrcode read from my mobile camera ,and that qrcode contains, a url (my website link) + some parameter. currently I can only open home page of my app, when i try to read qrcode through mobile camera. How can i read the parameter from the url? Please do reply it's urgent
I have tried this
onOpenUrl: {
    console.log("onOpenUrl:", url);
    var urlInfo = AppFramework.urlInfo(url);
    if (!urlInfo.host.length) {
        console.log("onOpenUrl parameters:", JSON.stringify(urlInfo.queryParameters, undefined, 2));
urlInfo is blank and "onOpenUrl parameters:" consoles undefind
ErwinSoekianto
Esri Alum
@x_d
What does the console.log say? Is it the expected URL? If yes, the rest is just processing the URL object.
Your code looks correct and it is very similar to the sample, you can also look at the example of this on Survey123 template source code, Survey123/template/SurveyApp.qml around line 219, onOpenUrl signal. I am using Survey123 3.11 and AppStudio 4.4
Thank you,
Erwin
x_d
@ErwinSoekianto  Thanks for your reply. And I'm getting the expected url, but when I'm trying to split the parameter from the url then it's not working.
 can you suggest me how to get separate the parameter from the url and then redirect to next page
onOpenUrl: {
         console.log("Open url is:"+url)//suppose the url contains
                  "https://www.arcgis.com/home/index.html+refno=12345"
         var ref_no= url.split('=')[1]; //to grab my required parameter which is 12345
console.log("REF No Returns:"+ref_no)// it prints nothing total blank
StackView.push("new_page.qml");
