Having trouble adding a map to a newly created app.
3457
08-04-2015 03:00 PM
PhilipPahl
When I go to add a map, nothing shows up in the "My Content" section.  I have a few web maps and packages present when I go to my content under ArcGIS online.
Any ideas?
GarethWalters
Hi Philip,
Could you please be more descriptive of your issue? Are you working inside of the AppStudio Online template workflow? If so, are you trying the Map Viewer as that is the only app that allows you to use web maps?
Look forward to hearing from you.
Cheers,
Gareth
PhilipPahl
My apologies.
I am indeed using the Map Viewer.
When I go to the Map Viewer Settings to set the maps I want to use in the
app, nothing is showing up in the My Content section.
I now only have 1 webmap in My Content when I go to ArcGIS Online directly.
Any idea as to why it will not show up in the AppStudio?
PhilipPahl
I figured out my issue thanks to a reply to another post.
I had not made my webmap public.
