Error on the Cloud Make
3396
6
05-07-2021 08:06 AM
JorgeFrade_Martínez
My apps goes blank after install...
A week ago I compiled an application and it worked perfectly.
Today I have compiled the same code and it does not work.
I have also tried with code from 5 months ago and it gives the same result.
Are there any changes in the latest appstudio update that make the application boot from qtCreator but not once compiled?
ErwinSoekianto
Esri Alum
Closing the loop on this one, that we were able to resolve this issue by removing the deprecated import ArcGIS.AppFramework.Controls.
ErwinSoekianto
Esri Alum
@JorgeFrade_Martínez
There is a chance that your app was built using AppStudio 4.4 or earlier and today the Cloud Make servers are based on AppStudio 5.0, I would recommend downloading AppStudio 5.0 Desktop or Player to test your app.
Erwin
JorgeFrade_Martínez
Yes, the application was created with appstudio 4, but I have added changes using AppStudio 5.0.148.
Everything looks great as I develop. But once I compile, (Windows, Android, iOS) the app never starts and everything goes blank...
I didnt test it on linux.
JorgeFrade_Martínez
@ErwinSoekiantoany update on this?
ErwinSoekianto
Esri Alum
JorgeFrade_Martínez
Sorry for the delay.
There are some others situations that refuses to work correctly with this new version for example the strangest one...
Having 2 labels inside a RowLayout, each label using part of the parent width, that sumes the total of the parent width, produce a crash.
RowLayout{
	Layout.preferredWidth: parent.width*0.8
	Label{
		text: "A"
		Layout.preferredWidth: parent.width*0.4
	Label{
		text: "B"
		Layout.preferredWidth: parent.width*0.6
I can understand why, but is strange that the new version crashes widout saying anything.
ApplicatioOutput:
The program has unexpectedly finished.09:32:00: Debugging has finished
General Messages:
"C:\Users\jlgomez\Applications\ArcGIS\AppStudio\5.0\bin\AppRun.exe" finished
I solved it by changing the width to parent.width*0.5.
A greeting!
JorgeFrade_Martínez
I have only 1 more error.
Can you provide more information to solve this?
Im using the NetworkRequest Type from ArcGIS.AppFramework 1.0.
