Error during cloud make for Android
7596
13
07-06-2021 10:06 AM
by Anonymous User
Not applicable
Hello Friends,
I am building an App in AppStudio. I have generated the keystore file using the command: keytool -genkey -v -keystore [keystore_name].keystore -alias [alias_name] -keyalg RSA -keysize 2048 -validity 10000 as mentioned here https://doc.arcgis.com/en/appstudio/extend-apps/signyourapp.htm under section Sign your Android app .
Surprisingly, when I run the command it doesn't ask me to perform step 7, Enter a key password. This password can be unique, or press Enter to use the same password as the keystore password. Without asking me to enter Key password the Keystore file gets genearted with .keystore extension. I have linked this keystore file with my App by going to settings>platforms>Android , KeyStore file path.
Now, when I do cloud make we have to enter KeyStore and upload key passwords, here I enter the same password for both KeyStore and Upload key, which I have entered for my KeyStore file while generating it using the keytool. When I start the make processs, it gives me the below error
Any help on this is much appreciated.
Rauf
by Anonymous User
Not applicable
Hi Carlos/ Erwin,
Try adding flag -storetype jks to the keytool command  as below:
keytool -genkey -v -keystore {Name].keystore -alias [Alias] -storetype jks -keyalg RSA -keysize 2048 -validity 10000
Apparently in order to perform cloud/local make for android platform using AppStudio, the keystore file should have .jks extension or if you are following the AppStudio documentation  https://doc.arcgis.com/en/appstudio/extend-apps/signyourapp.htm then add flag -storetype jks to the keytool command mentioned in that article.
Once I generated Keystore file using the above mentioned keytool command, I was able to successfully perform the cloud make.
Esri team should update the link  https://doc.arcgis.com/en/appstudio/extend-apps/signyourapp.htm to include this information.
I hope this will help.
Rauf
ErwinSoekianto
Esri Alum
Rauf,
It looks like there is an issue with the password, can you try changing the password to not use special characters?
Erwin.
Carlos_Carvalho
Hi Erwin,
I'm having the same issue. I changed the password for letters only but i get the same error.
Can you help?
Thanks.
by Anonymous User
Not applicable
Hi Carlos/ Erwin,
Rauf
by Anonymous User
Not applicable
Generating keystore using the below command should also work.
keytool -genkeypair -alias upload -keyalg RSA -keysize 2048 -validity 9125 -keystore keystore.jks
Carlos_Carvalho
DavidPuckett
Exact same issue and this is exactly what I needed to solve the same problem. Thank you
The documentation absolutely needs to be updated to include the -storetype jks flag in the command, here
@ErinMerrill @AndrewBladon
CarlosCarvalho
I get the following error "jarsigner: key associated not a private key" when I try to build a maptour app on appstudio using cloud make.
I have been using this keystore in the past and always worked until now.
Any ideas about this issue?
Thanks
Carlos_Carvalho
Thanks RaufShaikh, it worked.
Thanks for your advise, I appreciate it.
kind regards
by Anonymous User
Not applicable
Hi Carlos,
I am glad it helped. Could you please mark it as accepted solution?
Rauf
