Error downloading images on iOS devices
2246
10-04-2019 03:49 AM
JorgeFrade_Martínez
I can not download any image on iOS but works perfectly on Windows and Android.
NetworkRequest {
    url: "https://example.example.com/api/currentimage"
    responsePath:AppFramework.userHomeFolder.filePath("ArcGIS/AppStudio/pipo.jpg")
    headers.json: {"My-Key": "PIPO"}
    property url imagePath: AppFramework.resolvedPathUrl(responsePath)
    onReadyStateChanged: {
        if ( readyState === NetworkRequest.DONE ) {
            //console.log("downloaded image")
            selected.obtainedImagePath = imagePath;
            busyIndicator.running=false;
            //console.log(imagePath)
            selected.mustUpdate = false;
Any idea?
StephenQuan1
Hi Jorge,
Thank you for your reply.
I have rewritten the example as a complete working application so you should no longer have issues running it.
In my of my code today, I now use the FileInfo object, with this:
  1. You get automatic shortcut to AppFramework.userHomePath via "~"
  2. You can get the physical path, i.e. FileInfo.filePath
  3. You can get the url (useful to assigning to Image.source), i.e. FileInfo.url
  4. You have access to the container folder via FileInfo.folder which is a FileFolder object which you can use to do folder operations, such as fileExists, delete, makeFolder
I hope you find this example more useful.
Stephen
StephenQuan1
Make sure the folder exists.
Use FileFolder.makeFolder() to do this.
import QtQuick 2.12
import QtQuick.Controls 2.12
import QtQuick.Layouts 1.12
import ArcGIS.AppFramework 1.0
App {
    width: 400
    height: 640
    property FileInfo target: FileInfo { filePath: "~/ArcGIS/AppStudio/Images/logo.png" }
    ColumnLayout {
        anchors.fill: parent
        anchors.margins: 10
        Image {
        NetworkRequest {
            url: "https://appstudio.arcgis.com/images/index/logo-appstudio.png"
            responsePath: target.filePath
                if ( readyState !== NetworkRequest.ReadyStateComplete ) return;
                image.source = target.url
        Button {
            text: qsTr("Download Now")
            onClicked: {
                target.folder.makeFolder();
                networkRequest.send();
        Item {
            Layout.fillHeight: true
JorgeFrade_Martínez
The FileFolder don't have a property named filePath... That throws me an error.
If i change it to path, then throws this error:
TypeError: Property 'makeFolder' of object function() { [native code] } is not a function
Have you tried that code before posting it?
StephenQuan1
Hi Jorge,
Stephen
