Done Button Causing App Crash
1671
08-31-2016 06:13 PM
DustinBaumbach
Hi Esri Team,
I have been working with another person to implement the multiple photo upload option and have implemented that code successfully. However, now when I get to the Add Details portion of my quick report app, pressing the done button in the bar above the preset domain options causes my app to crash. Has anyone encountered this problem and what would be the best way to go about fixing it? I look forward to hearing any suggestions and would be willing to send you my code if anyone would like to have a look.
Thank you,
Dustin
AdrianWelsh
MVP Honored Contributor
Dustin,
This may need to be bumped up to Esri Technical Support. You might want to consider giving them a call if you have not found a solution yet.
DustinBaumbach
Hi awelsh_mei‌,
I have not found a solution to this problem yet. I am going to try calling Esri Technical Support on Monday when my account lead gets back from vacation. I will post an update when I find out more information from tech support.
