Debugging in AppStudio
1696
11-17-2017 08:40 AM
KrishV
Hello Everyone,
For JavaScript debugging, I have followed documentation given at below link:
http://doc.arcgis.com/en/appstudio/extend-apps/debuggingjavascript.htm
Please find my system details:
OS: Windows 10
Installed WDK for Windows 10, Version 1703
Installed qt-opensource-windows-x86-msvc2015_64-5.8.0.exe
After following all the steps in documentation, I'm getting below error:
Starting C:\Qt\Qt5.8.0\5.8\msvc2015_64\bin\qmlscene.exe...
file:///C:/Users/esri/ArcGIS/AppStudio/Apps/Feature Layer/MyApp.qml:24 module "ArcGIS.AppFramework.Controls" is not installed
file:///C:/Users/esri/ArcGIS/AppStudio/Apps/Feature Layer/MyApp.qml:23 module "ArcGIS.AppFramework" is not installed
C:\Qt\Qt5.8.0\5.8\msvc2015_64\bin\qmlscene.exe exited with code -1
Please suggest how to proceed..
Regards,
Krish
nakulmanocha
Are you working on AppStudio 2.0 or 2.1?
if 2.0 your Qt version must be Qt 5.8 - msvc2013
if 2.1 - Qt 5.9.1 - msvc2015
KrishV
Hello Nakul,
Thanks for your quick response.
I'm using AppStudio 2.1. Can you provide link to download Qt 5.9.1 msvc 2015? Link provided in documentation doesn't have Qt 5.9.1 msvc 2015. PFB link:
Index of /archive/qt/5.5/5.5.1
I have installed qt-opensource-windows-x86-msvc2015_64-5.8.0.exe.
Regards,
Krish
nakulmanocha
You need go to qt webpage and look for downloads.
On the side note. You can use console.log("messages") within your javascript code to debug your code. That is easiest and the fastest way to debug. Plus you can use the Qt which comes with AppStudio. You don't need to install anything other than AppStudio.
KrishV
Hi Nakul,
I have checked Qt Webpage and looked for Qt 5.9.1 MSVC 2015 but I didn't find anything for Windows 64 bit. Can you provide me link to download this Software. As I mentioned in my earlier reply, this software is not available.
Regards,
Krish
KrishV
I have installed QT 5.9.1 and followed steps in AppStudio Documentation and now, I'm getting attached screenshot.
If i run the code, I'm getting below errors:
Please help to resolve this issue.
Regards,
Krish
