Can we use Just XForm code only from survey123 template in AppStudio for a native apps we create to fulfill our usecase?
1388
01-18-2018 11:44 PM
GeoDevPathways_Data
Is it possible i just use Xform code?
nakulmanocha
I am not sure whats your end goal and what exactly you mean?
Are you saying 1) Can you use the Xform code found in Survey123 in other native apps?
Or 2) Or Can you just use that code don't add any other code?
But yes you should be able to use the XForm code to create your apps
Nakul
GeoDevPathways_Data
Thank you for the respond. I actually want it in my native apps where I want to use  it as form like Survey123.
