Can't identify the clustering point layer
995
06-30-2020 07:10 PM
simoxu
by MVP Alum
I am trying to make the Web Map example working for the a webmap with a clustering point layer in it. I have enabled the popup for the clustering layer and configured the clustering-popup. it works fine in the map viewer and other applications in AGOL, but it doesn't work in this example.
Does Qt runtime for ArcGIS support clustering popup at all? or it is just this example.
Thanks.
Tags (1)
ErwinSoekianto
Esri Alum
Simo,
I think feature layer clustering is not supported in ArcGIS Runtime SDK for Qt‌. Tagging Runtime SDK for Qt in this thread for visibility.
I would recommend bringing this up in ArcGIS Ideas‌ or create an official Enhancement request via Esri Technical Support‌.
Thank you,
Erwin
ErwinSoekianto
Esri Alum
Simo,
Thank you,
Erwin
