AppStudio Survey123: How to Remove Start Page with Sign In?
3183
6
08-27-2019 10:42 AM
AlexP_
Hello,
Please see screenshot as reference. I have an AppStudio 3.3 Desktop Edition with Survey123. How do I remove start page with sign in? I edit in QT Creator. Please advise as soon as possible. Thank you for your assistance.
Image result for survey123 start page field app
cc: Survey123 for ArcGIS
ErwinSoekianto
Esri Alum
Alex,
Removing this line works for me, Survey123/template/SurveyApp.qml
Thank you,
Erwin
ErwinSoekianto
Esri Alum
Alex,
Thank you,
Erwin
AlexP_
Hello,
It is working. Thank you for your reply but it is unexpected because now surveys are gone. Am I doing something incorrect? I am trying to display surveys without download and without sign in as well. Please advise. Thank you for your time.
ErwinSoekianto
Esri Alum
One of the reasons this page appears in the first place is because there is no survey downloaded in the device.
Depending on your workflow, I would prepare a survey that is shared publicly and then scan the QR code on the device, after that the app will download that survey into your app.
AlexP_
Please see screenshot. Survey is already shared to publicly. I scanned QR code on device appstudio player and it is what display. Do I need to register AppClient/AppID to display surveys without sign in?
ErwinSoekianto
Esri Alum
Sharing public survey, scanning QR code on the device for Survey123 is covered in this doc, https://community.esri.com/groups/survey123/blog/2016/11/10/getting-started-with-public-surveys
I think what you did wrong was scanning the Survey123 QR Code in AppStudio Player, they are different. Scanning QR code in AppStudio Player is to open AppStudio apps. (This has nothing to do with the AppID or ClientID)
Thinkoutsidescott
Hi Erwin,
I'm not sure if my last reply posted correctly so I apologize if this is redundant. I have tried to implement the workaround that you posted above in the latest version of Survey123 however I am unable to find the files you specified in QT Creator. My goal is similar to what the original post is asking. I'd like to point my white-labeled Survey123 app directly to one specific survey and also skip the login page since this is meant for public use and the people submittng the surveys do not have/need AGOL credentials.
Thank you,
Scott
