AppStudio Survey123: How to Display Surveys without Download?
3128
6
09-05-2019 07:12 AM
AlexP_
Hello,
Please see screenshot. I have an AppStudio 4.0 Desktop Edition with Survey123. Edit in QT creator. Is there a way to display surveys without download surveys? *no sign in/no portal. Just for the public use. Please advise. Thank you!
cc: Survey123 for ArcGIS‌ cc: AppStudio for ArcGIS
AlexP_
Erwin Soekianto,
I read the link you posted but it is display and open only one survey. Is it possible to display more than one survey? Please let me know.
Thank you.
Alex
YuliaMamonova
Hi Alex,
I tried parsing several item ids, but it only downloads by one each time you open the app. Did you get it work?
YuliaMamonova
Hi Erwin,
I tried for loop to iterate through an array with item ids that I want to download, but it still only downloads the first one when I run. Please look at my code:
THANK YOU!!!
ErwinSoekianto
Esri Alum
Yulia,
To my knowledge, using this approach (hijacking the itemid on the open paramater) can only open one Survey at a time, because this is the same as if we are opening the Survey123 field app using custom URL Scheme. https://community.esri.com/groups/survey123/blog/2016/07/30/understanding-survey123s-custom-url-sche...
We need to think about a different approach if we want to pre-load more than one survey.
Erwin
YuliaMamonova
Erwin,
So should I work with OpenParameters page? Could you please suggest what changes should I make to make it finally work?
Thank you!
