AppStudio for ArcGIS / Memory leaks
6453
12
01-10-2017 06:53 AM
RodrigoPintos
Hi, im working with the AppStudio for ArcGIS and I noticed that the memory is not released properly in many applications made by Esri like Palm Spring Map Tour, Map Tour, Survey 123 (when i use de barcode scanner)
BarcodeDecoder:
I'm developing an application where i have to use a barcode scanner and after some failed barcode scanning the memory usage increase too much.
As i was having troubles with it, I downloaded and used exactly the same code of the survey 123 to decode barcodes and I still having the same behaviour.
The same happens with the barcode scanner of the AppStudio Player.
Map:
AppStudio for ArcGIS / Map memory leaks
I attached some videos
Any help will be greatly appreciated.
RodrigoPintos
I also test what you told me, I take only one Image, and try by decoding repeatedly and i got memory leaks so I think the problem is with the BarcodeDecoder controler when decoding
StephenQuan1
Hi Rodrigo,
Our QR code scanner has two modes.
One, as you discovered, takes a screenshot and analyses the screenshot, aka. scanMode = scanModeGrab.
From what you're saying, there appears to be a memory leak within scanGrab() which we need to narrow down. Your last conclusion is it is possibly withing the BarcodeDecoder itself, but, I just wanted to be sure.
The other scan mode, scanMode = scanModeCapture takes a photo and saves it to a JPEG file which we subsequently use to process the image. Can you try switching to this mode to see if the memory utilization is, either, better, same or worse?
Stephen
RodrigoPintos
Hi Stephen,
I have tested the application again, this time with scanMode = scanModeCapture. I took an image and I started decoding it repeatedly. The memory is still leaking.
In my opinion, the problem is in the BarDecoder component which is not releasing the memory properly.
In the  AppStudioPlayer-BarCodeScanner.mp4. video I attached previously, you can see how "Scan QR Code" within AppStudio Player, has the same behaviour.
In both videos , the upper leftmost part of the screen show the decrement of memory for each barcode scan.
PD.
I would suggest to make the following changes to  survey123 ( in order to destroy "res" after grabToImage)
videoOutput.grabToImage(function(res) {
                res.destroy();
and perhaps make the imageObject dynamic.
