AppFramework.file.readAll()
1936
06-11-2020 07:22 AM
Mike_Quetel
I'm attempting to read JSON from a configuration file using file.readAll().  I can open and perform the read, but can't figure out how to convert the ArrayBuffer to a string or ultimately I want to make use of the JSON in the file.
Considering the file "foo.json" in my data folder:
	"name": "value",
	"things": []
I'm reading it using the following code:
    function readConfig() {
        var file = AppFramework.file(AppFramework.userHomePath + "/ArcGIS/Runtime/Data/foo.json");
        if (file.exists) {
            if (file.open(File.OpenModeReadOnly)) {
                var data = file.readAll();
                // get the json?
                file.close();
but I can't seem to get the text or JSON from the binary data that readAll() returns.  It looks like I could use a loop and readLine() which returns a string, then check for file.atEnd, but it seems like there must be a better way.
Obviously I'm new on the QML/JS journey and would sure appreciate a push in the right direction.  Thanks in advance!
Tags (3)
by Anonymous User
Not applicable
Hi Mike
In the AppFramework of AppStudio there is a component called FileFolder which has methods to read/write json (and text) files which you could probably use here.
FileFolder QML Type | ArcGIS
e.g. something like:
const folder = AppFramework.fileFolder(AppFramework.userHomePath + "/ArcGIS/Runtime/Data");
const jsonData = folder.readJsonFile("foo.json")
console.log(JSON.stringify(jsonData))
Mike_Quetel
This code snippet works fine, but  its seems silly/inefficient to have to loop through a file like this:
let data = "";
let file = AppFramework.file(filePath);
if (file.exists) {
    	do {
        	data += file.readLine();
    	} while (!file.atEnd)
        file.close();
        try {
            let json = JSON.parse(data)
            return json;
        } catch(err) {
        	console.log("Failed to parse JSON, error returned '" + err.messsage + "'");
return null;‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
by Anonymous User
Not applicable
Hi Mike
Mike_Quetel
Thank you! Much simpler than my approach.
