I have a map layer consisting of polygon areas. Is there some sample code available to show how I can label these polygons with one of the attribute fields such as the area name or number? They are displayed with a Feature Layer.
Your feature layer should be symbolized (and labeled) in your published map document. Make sure you're not using Maplex and any scale dependencies are properly set.
