Zoom to Selected Record & Scale Range for Graphic and feature Layer
4691
06-19-2011 10:11 PM
MuhammadWaqar_ul_islam
i have selected records in slData:DataGrid through query
i want to zoom to selected record in data grid (required code C#)
and
how to define  Scale range for  Graphic and feature layer
DominiqueBroux
Esri Frequent Contributor
You can call Map.ZoomTo  with the geometry extent of your selected graphic.
This is working well if your geometry is a line or a polygon.
If it's a point, you have to create an envelope around the point (with a size depending on the zoom level you are expecting) and call ZoomTo with this envelope.
angelasuch
please explain how to  'create an envelope around the point'.
DominiqueBroux
Something like:
var env = new Envelope(point.X - size/2, point.Y - size/2, point.X + size/2, point.Y + size/2);
env.SpatialReference = point.SpatialReference;
