Zoom to select Query results
1068
12-16-2010 01:45 PM
DavidAshton
I have a simple query, which is working great...populates my tablegrid but I'm having trouble with the zoom to selected feature functionality.  Can someone help?
        #region Attribute Query
        private void ExcuteAPNQuery_Click(object sender, RoutedEventArgs e)
            GraphicsLayer selectionGraphicslayer = Map.Layers["MySelectionGraphicsLayer"] as GraphicsLayer;
            selectionGraphicslayer.ClearGraphics();
            QueryTask queryTask = new QueryTask("http://dgpdch01/ArcGIS/rest/services/Parcels/MapServer/0");
            queryTask.ExecuteCompleted += AQueryTask_ExecuteCompleted;
            queryTask.Failed += AQueryTask_Failed;
            Query query = new ESRI.ArcGIS.Client.Tasks.Query();
            query.Where = string.Format("APN = '{0}'", FindAPN.Text);
            query.OutFields.Add("*");
            query.Text = FindAPN.Text;
            _queryTask.ExecuteAsync(query);
        private void AQueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
          //  FeatureSet featureSet = args.FeatureSet;
         //   GraphicsLayer graphicsLayer = Map.Layers["MySelectionGraphicsLayer"] as GraphicsLayer;
         //   if (MySelectionGraphicsLayer = null && MySelectionGraphicsLayer.Features.Count > 0)
               // Graphic feature = featureSet.Features[0];
               // foreach (Graphic feature in featureSet.Features)
                //    feature.Symbol = LayoutRoot.Resources["ResultsFillSymbol"] as FillSymbol;
                //    graphicsLayer.Graphics.Insert(0, feature);
                    // Zoom to selected feature (define expand percentage)
                    ESRI.ArcGIS.Client.Geometry.Envelope selectedFeatureExtent = Feature.Geometry.Extent;
                    double expandPercentage = 30;
                    double widthExpand = selectedFeatureExtent.Width * (expandPercentage / 100);
                    double heightExpand = selectedFeatureExtent.Height * (expandPercentage / 100);
                    ESRI.ArcGIS.Client.Geometry.Envelope displayExtent = new ESRI.ArcGIS.Client.Geometry.Envelope(
                    selectedFeatureExtent.XMin - (widthExpand / 2),
                    selectedFeatureExtent.YMin - (heightExpand / 2),
                    selectedFeatureExtent.XMax + (widthExpand / 2),
                    selectedFeatureExtent.YMax + (heightExpand / 2));
                    Map.ZoomTo(displayExtent);
                ResultsDisplay.Visibility = Visibility.Visible;
            _drawSurface.IsEnabled = false;
        private void AQueryTask_Failed(object sender, TaskFailedEventArgs args)
            MessageBox.Show("Query failed: " + args.Error);
DominiqueBroux
Esri Frequent Contributor
What kind of trouble?
In your code, where is coming the 'Feature' from?
As a side note, in 2.1 an 'Expand' method has been added to Envelope class.
DavidAshton
dbroux,
Thanks for the reply.  I got it.
Dave
