Zoom to featurelayer extent issue
4353
9
06-25-2012 11:16 PM
bayramüçüncü
In the following code I wanna zoom to selected city. But zoom is unsuccessful.
        private void ctxQueryComBox_SelectionChanged(object sender, SelectionChangedEventArgs e)
            City selectedCity = ctxQueryComBox.SelectedItem as City;
            FeatureLayer layer = Map.Layers["cityFeature"] as FeatureLayer;
            if (layer == null || selectedCity ==null)
                return;
            layer.Where = string.Format("CityId = '{0}'", selectedCity.Id); // query
            layer.Visible = true;
            layer.Update();
            Map.Extent = layer.Geometry.Extent;
            cxDatagrid.GraphicsLayer = layer;
when I selected the city from the combobox, zoom not working.
JoeHershman
In order to use the 'Updated' FeatureLayer you need to add a handler for the UpdateComplete Event and than have your code run inside that handler
Something along these lines
layer.UpdateComplete += (s,e) => {
layer.Update();
-Joe
bayramüçüncü
layer.Update();
I tried these codes to order,
layer.UpdateCompleted += (snd, evt) => { new Envelope(399368, 4466618, 568578, 4568478); };
layer.UpdateCompleted += (snd, evt) => {  Map.Extent = layer.Geometry.Extent; };
layer.UpdateCompleted += (snd, evt) => {  Map.ZoomTo(mevt.layer.Geometry.Extent); };
layer.UpdateCompleted += (snd, evt) => { Map.ExtentChanged += (msnd, mevt) => { Map.ZoomTo(mevt.NewExtent);}; Map.Extent = layer.Geometry.Extent;  };
but not worked
JoeHershman
Have you tried
layer.UpdateCompleted += (snd, evt) => { Map.Extent = layer.FullExtent; };
Good Luck
-Joe
KenDoman
When I try this code, I get this error:
'Public Event UpdateCompleted(sender As Object, e As System.EventArgs)' is an event, and cannot be called directly. Use a 'RaiseEvent' statement to raise an event.
Basically, I can't programmatically add an UpdateCompleted event to a new Feature Layer.
DominiqueBroux
Esri Frequent Contributor
Likely there is a syntax error in your code. You should be able to wire up an handler to the event UpdateCompleted.
How does your code look?
KenDoman
Here's my code in VB.NET
            Dim featureLayer As FeatureLayer = New FeatureLayer() With {.ID = "DataLayer"}
            featureLayer.UpdateCompleted = Sub(snd, evt) MyMap.ZoomTo(featureLayer.FullExtent)
Here's the error that's returned:
DominiqueBroux
The syntax to wire up an handler to an event is '+=' not '='
featureLayer.UpdateCompleted += Sub(snd, evt) ......
KenDoman
I tried that one, and it still gave me the same error.
After searching around, I eventually found out how to set up the event handler in vb.
' skip other setup code
AddHandler featureLayer.UpdateCompleted, AddressOf FeatureLayer_UpdateCompleted
' a little later...
Private Sub FeatureLayer_UpdateCompleted(ByVal sender As Object, ByVal e As EventArgs)
    Dim myExtent As ESRI.ArcGIS.Client.Geometry.Envelope = CType(sender, FeatureLayer).FullExtent
    If myExtent IsNot Nothing Then
        MyMap.ZoomTo(myExtent)
    End If
End Sub
The full extent is empty, but at least it's firing now.
DominiqueBroux
Ohh yes.
Looks like I got lost between C# and VB syntax.
Sorry about that.
