Zoom past last tile
762
01-25-2011 09:11 AM
ChristineZeller
I thought I've seen this question on the forums before but I couldn't locate so I apologize for this post if it is a duplicate.
I have serveral dynamic services and several tiled services and I want to be able to zoom in past the last tile.  It seems like my zoom is snapped to various tiled levels but i want to be able to move past the last tile (even if the users sees the "data not available for the imagery/base tiled layers")
How can I accomplish this?
Chris
JenniferNery
dotMorten_esri
Esri Notable Contributor
Set Map.MinimumResolution. By default the map sets it to the resolution of the last tile in the tiled layers. However you can override this by explicitly setting it. Note that this will make these tiles stretch beyond what they were meant for. You can in turn avoid this by setting myTiledlayer.MinimumResolution to the resolution of its lowest LOD. That way the tiled layer will turn off when you pass this point, and the dynamic layers will be the only thing visible at this point.
