writeablebitmap has protected content. how to solve?
1884
04-13-2013 03:16 AM
MayurDodiya
how to solve "writeablebitmap has protected content. pixel access is not allowed." issue ?
any idea ?
PhilipKnight1
This thread has some good stuff in it: [HTML]http://forums.arcgis.com/threads/20903-Export-map-to-png[/HTML]
but from what I quickly googled, the biggest issue with thsi seem sot be that in silverlight you can't get a screendump of something that is not in the same domain as the xap you are using.
DominiqueBroux
Esri Frequent Contributor
As noticed in the referenced thread, the workaround might be to use the ProxyUrl property to push the tiles through the proxy so it will look like it comes from the same domain.
MayurDodiya
HI..Thanks for reply..
Well, I am not sure for how to use ProxyURl property..? any samples or steps how to use Proxypage in silverlight ?
my project is in same domain only but even though i am getting this error ..i tried the best but not getting it exactly how to solve it?
DominiqueBroux
You can run into this problem as soon as your tiles are coming from another domain (which is most generally the case)
You'll find some info about setting a proxy in this Silverlight viewer documentation (but you don't need to set up a token if your servcies are not secured)
