WPF access of image tiles in bundle (compact) format?
1411
03-02-2011 01:59 PM
MarkPing
I have a map service on the desktop that's using pre-generated cached tiles.  Right now, the tiles are in exploded form, which is a huge number of files.  So I say to myself, "self, I should be using the new 'compact' tile format."  It's easy to generate, but I can't find any documentation at all on how to use it.
While offline, my program gets the ArcGISTiledMapServiceLayer_TileLoading event and can use the exploded files (using layer/row/column).  How do I convert this logic into using the compact cache?
I can't find anything in the forums/ online docs /etc on this.
dotMorten_esri
Esri Notable Contributor
AFAIK the compact cache format is not documented publicly - at least not yet. You might want to ask in the server forum about the compact cache format.
MarkPing
I figured it wasn't documented, but I was hoping for an interface class, etc. in the framework to access to compact format.  Nothing like that?
davidrenz
Mark,
did you ever figure this out?
am in the same boat and would rather use the compact cache.
thanks
david
MarkPing
Yes, I met Morten at the dev summit and he sent me some code (first in javascript, then his own code in C#).  I think he's made it public, but I'll double-check with him.  Ah, here it is released to the public:
http://www.arcgis.com/home/item.html?id=04f934a3a2d4483bb3126c199d6ed077
