WindowPanel limit position
1212
12-21-2010 11:18 PM
DmitryAleshkovsky
When i drag my windowpanel over application window, i can drag winodow's header under the browser toolbar and under browser command line. After i release mouse button i can't get window back (look attachment).
How to limit windowpanel position inside application window?
DominiqueBroux
Esri Frequent Contributor
The window panel is not designed for that, but you might find ideas about the controls to use on this thread:
http://forums.arcgis.com/threads/8403-Is-there-any-SL-control-that-acts-like-floating-panel
DmitryAleshkovsky
dbroux!
thank you for reply. I'll look for your link
The window panel is not designed for that[/URL]
It is interesting,what window panel is designed for? 🙂
DmitryAleshkovsky
Hope, now Window Panel is designed for that
for WindowPanel.xaml.cs
        private void headerDragRectangle_MouseMove(object sender, MouseEventArgs e)
            if (isTrackingMouse)
                Rectangle rect = sender as Rectangle;
                Point point = e.GetPosition(null);
                double aWidth = Application.Current.Host.Content.ActualWidth / Application.Current.Host.Content.ZoomFactor;
                double aHeight = Application.Current.Host.Content.ActualHeight / Application.Current.Host.Content.ZoomFactor;
                if (point.X < 0) point.X = 0;
                if (point.Y < 0) point.Y = 0;
                if (point.X > aWidth) point.X = aWidth;
                if (point.Y > aHeight) point.Y = aHeight;
                double x0 = this.renderTransform.X;
                double y0 = this.renderTransform.Y;
                double sign = 1;
                if (FlowDirection == System.Windows.FlowDirection.RightToLeft)
                    sign = -1;
                this.renderTransform.X = x0 + (point.X - mouseOffset.X) * sign;
                this.renderTransform.Y = y0 + point.Y - mouseOffset.Y;
                mouseOffset = point;
