When is map Loaded called
1119
07-26-2010 09:57 PM
xariaD
I need to do some processing on the feature layer after the map is loaded.
How can I capture Map Loaded event complete?
After the map is loaded I need to do the following
private void ProjectFeatures()
FeatureLayer newFeaturelayer;
            newFeaturelayer = MyMap.Layers["myFeaturelayer"] as FeatureLayer;
            Graphic feature = new ESRI.ArcGIS.Client.Graphic();
            int[] statuses = MyWebServiceProxy.GetAllStatus(UserInfo.username,1);
            for (int i = 0; i < 12; i++)
                   feature = newFeaturelayer.Graphics;
                   if (statuses == 0)
                       feature.Attributes["Status"] = "Off";
                       feature.Symbol = this.MainGrid.Resources["MyRedFillSymbol"] as SimpleFillSymbol;
                   else
                       feature.Attributes["Status"] = "On";
                       feature.Symbol = this.MainGrid.Resources["MyGreenFillSymbol"] as SimpleFillSymbol;
If I call this in  private void MyMap_Loaded(object sender, RoutedEventArgs e)
            MyMap.Rotation = 90;
            ProjectFeatures();
I get System.ArgumentOutofRange exception at   feature = newFeaturelayer.Graphics;
Where will be the appropriate place to invoke this function.
DominiqueBroux
Esri Frequent Contributor
It means that at this stage the graphics are not existing yet --> call this function after the graphics of your feature layer are loaded.
So it's depending on where your graphics are coming from:
    - if defined in xaml --> call your function in the Initialized event of the feature layer
    - if defined by code --> call it after this code
    - if coming from a feature layer --> call it in the UpdateCompleted event
xariaD
Thanks Dominique
I'll try calling the code in UpdateCompleted
