Problem querying  Using Silverlight 4
800
06-21-2010 12:45 AM
AymanHdaib
On querying a point or polygon feature in an ArcGIS server 9.3.1 application developed using Silverlight 4, the application either hangs or takes abnormally long time to respond In Our ArcGis Server.
However, when the query is off, the features appear immediately and behaves normal.
The same is not the case when we run the application in Silverlight 3, it runs smooth and the response to query is fast.
But when I Use The ESRI Services it's work fine in Silverlight 4 i Think There is a problem in our ArcGis Server
but how i Can solve it
What could be the reason?
note :
ESRI tool kit is V.2.0.50727
.Net Framework 4
Silverlight v.4
AaronCropper
We have the same exact issue.  Our queries work fine in Silverlight 3 and in 4 with it takes abnormally longer to respond.  have you figured this out yet?  We may be forced to stick with 3 until this is resolved.
