What is the function to close the window FeatureDataForm?
1454
07-19-2012 02:46 AM
FabienNAPPA
I added a Cancel button in FeatureDataForm.
But I do not know how to close the window (Form) !
Thank's,
Fabiano
JoeHershman
Thank you for your response.
But, how to remove the parent container after pressing the button "Apply" ?
Thank's
Fabiano
FeatureDataForm has an EditEnded event which fires after the Apply button is clicked and the edit is applied.  Add a handler for the event and close the form there.
Good Luck
-Joe
JoeHershman
Just like any other user control set the Visibility to Visibility.Collapsed.  You might want to do it with the parent container of the actual FeatureDataForm
-Joe
FabienNAPPA
Thank's
Fabiano
JoeHershman
Thank's
Fabiano
Good Luck
-Joe
FabienNAPPA
It's working.
Thank you very much.
