We are having two issues regarding Feature services
We are creating feature services using sde.default its working & allow editing but if we create another sde user named sde1 and create geodatabase in it,and when we try to publish feature service for sde1 user's geodata then service will not be published and given error is register database and when we register the database for same user it will show that the databae is registered and when we republished it is showing the same error again.
does feature service only supports default sde user?
and second problem is that when we published the feature service with domains and sub types, apply button on the editor widget not active while editing,also not showing the domain's values.
best regards
