Version 3.0 and Server version 10 SP 5
3429
08-09-2012 08:30 PM
SanajyJadhav
Hello,
We have ArcGIS Server 10 SP 5 and won't be migrating to 10.1 soon.
I just wanted to know whether we can use API version 3.0 on Silverlight 4 for ArcGIS server 10 SP5 or not .I am sure Silverlight 4 is supported for version 3 but not about Server version 10 SP 5.
I am primarily interested in advanced query capabilities.
So, please let me know if Server version 10 SP 5 is supported for API version 3.0 or not.
Thanks.
vipulsoni
Hello,
Thanks.
You can indeed use ESRI Silverlight API 3.0 with ArcGIS Server 10 SP5 , it is supported. But not the functionalities of the 3.0 API which are dependent or available only from the ArcGIS Server 10.1 REST. You need to go through the documentation at http://resources.arcgis.com/en/help/silverlight-api/concepts/#/What_s_new_in_3_0/0166000000m9000000/
Support for new ArcGIS 10.1 for Server services and capabilities ----
Change layer rendering, layer order, or add layers on the fly in map services
Generate data classifications on the server for layers in map services
Use enhanced query options to order results and generate statistics
Track user identity for edits to a layer in a feature service
Generate printable output using the new PrintTask
Support for geometry with Z and M values
Support for new image service functionality
