Using the more recent Bing Maps Style
3149
11
03-26-2011 08:37 AM
LanceCrumbliss
Hi There,
How do I utilize the more recent Bing Maps style of tiles instead of the older ones?  I'm speaking of the Bing Map cartography displayed by default in this web app:
http://gis.cdatribe-nsn.gov/flashmaps2_1/
Lance
DaveTimmins
it should use the new style bu default as of May 1st. As per this link
LanceCrumbliss
interesting, thanks. I take it that there is no way to opt in currently then?
DaveTimmins
The only way to do it now would be to create your own Bing layer and specify the mapVersion parameter in the querystring of the request but that seems like a waste of time to me given that it's only a month until it will default to the new style. If you really wanted to do that I'd just use reflector to get the current code and update the request url.
FredericGoulet
It is May 4 and I do not see the new style for road.
Is it because I am located in Canada ?!?
Does anybody see the new style ?
dotMorten_esri
Esri Notable Contributor
According to the link Dave provided, it looks like Microsoft changed the date to July 6th.
FredericGoulet
Ha, too bad. 😞
Can we expect a new parameter "Version" be added to the bing.TileLayer in the next SDK release ?
I am eager to allow my users to use the new road map style, witch is much better suited for our application.
Frédéric
dotMorten_esri
Since the change will happen very close to the next release of the API (and originally prior to), we are not planning on adding a parameter that is as good as outdated already.
FredericGoulet
Nevertheless, a version parameter could be useful to opt in right away when updates is made to the bing maps style, without having to wait in the future.
dotMorten_esri
Unfortunately a version parameter would do no good, since the bing service doesn't expect a version number but a new enumeration value. Without an updated proxy (meaning a new build of the bing assembly), there's no way to set that value.
