Using Layers from the service
2800
03-08-2011 09:29 PM
ManojrajTeli
I have created a dynamic map service and it contains many layers such as asset layer satellite imagery etc.My question is is it possible to use only few layers from the service without using entire service because i need to add opacity features and etc for each layer.Thank you in advance
DominiqueBroux
Esri Frequent Contributor
Yes, you can change the viisbilities of the sublayers.
There is a sample here:  http://help.arcgis.com/en/webapi/sil...dWithTemplates
From the API, you have to use either the VisibleLayers property or the SetLayerVisibility method.
ManojrajTeli
Can we control the opacity of these sublayers...???
DominiqueBroux
[INDENT]Can we control the opacity of these sublayers...???
[/INDENT]
No, the opacity is defined at the server side and can't be changed at the client side.
ManojrajTeli
Thanks friend incase i have difficultly then i post that query.
