Using Editor Widget with Auto Update of Attribute
2636
12-19-2011 11:51 AM
EricKauffman
Hi all,
I have a simple app that uses the editor widget to add/move/remove points belonging to a feature class. What I need to do is have the application automatically set an attribute value that can't be changed by the user.
I see there are EditCompleted and EditActivated events, but I can't see how I'd use either to manipulate attribute values prior to a feature being saved.
Can someone point me to an example of doing this?
Thanks!
EricKauffman
Ok, I'm replying to my own thread! Here is how I did this:
On the EditorWidget add a handler to the Edit Completed event.
In the xmal code behind, when you do this, it will automatically create an event handler. Complete the handler using this pattern:
private void MyEditorWidget_EditCompleted(object sender, Editor.EditEventArgs e)
            foreach (Editor.Change change in e.Edits)
                if (change.Graphic.Attributes.ContainsKey("YOUR_COLUMN_NAME"))
                    change.Graphic.Attributes["YOUR_COLUMN_NAME"] = YOUR_NEW_VALUE;
JenniferNery
You might want to check EditAction (i.e. e.Editor.EditAction.Add), your code currently will set the attribute regardless of completed command.
If this is not a concern, you can also use FeatureLayer.BeginSaveEdits event, if any edit should trigger this attribute value change.
Another option is to update your service-defined PrototypeAttributes. EditorWidget contains TemplatePicker that allows you to add features based on feature type. Based on the selected feature type, a list of default attributes are used. This may be related thread: http://forums.arcgis.com/threads/46116-Template-Picker-and-Multiple-Domain-Values-2.3-and-10-SP3
