Using Attachment Editor With a Proxy
5367
10
12-22-2010 09:37 AM
WilliamDonahue
I have been using the attachment editor for a while now. Once i added a proxy to all my rest layers... the attachment editor still allows me to view and delete attachments, however on the downside I can not add attachments i keep getting an error stating:
is not a valid JSON primitive. This error can also occur when extraneous data is present after the JSON data.
If i remove the proxy it will allow the data to pass however the proxy is part of my security.
by Anonymous User
Not applicable
I've revised the proxy again.  It now supports use of SSL and Port numbers.  In addition this PHP proxy works with attachments but I believe there is a problem with token secured attachments.  I've not had the time to revisit this.
