User editing of data
1266
11-05-2010 08:34 AM
DonFreeman
There is a nice sample at http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#ToolkitFeatureDataForm which shows how to allow a user to edit the underlying attribute data. I can make this work with my own data up to the point where the editing table opens. At that point the data is visible but not editable. What do I need to do to allow editng of my data? Is there something in the service itself, or perhaps some server permissions that need set?
Thanks
JenniferNery
If you are using MapService or if your fields have Editable property to false, then the FeatureDataForm will display all fields as read-only.
DonFreeman
Thanks Jennifer. What type of service should I be using and where do I set the fields to editable?
How do I handle server permissions?
Thanks
JenniferNery
DonFreeman
You can learn more about FeatureService here: http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/What_is_a_fea...
OK, so as I read that info it says "All data must be from a single ArcSDE geodatabase." Implied meaning that it will not work with a shapefile.  So that leads me to wanting to implement the project using a related table rather than the actual attribute table. I think all I need to do this is the ability to click a feature on the map and capture the click event with the FID of the feature. I can then create my own query and bring up the needed record in a .NET datagrid. Is there a sample around that would show me how to do that?
Thanks
JenniferNery
This sample FeatureService includes a related table: http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/FeatureServer
You can edit the related table just as you would edit any feature layer. Post #2 here http://forums.arcgis.com/threads/16731-Change-value-of-FeatureDataGrid-Cell describes how it can be done.
