url map services
1542
6
07-26-2010 08:54 AM
AgatinoLa_Rosa
I have a map with three layers defined as below.
<esri:Map Name="baseMap">
<esri:ArcGISTiledMapServiceLayer ID="BaseLayer" Url="http://worldmap/MapServer"/>
<esri:ArcGISDynamicMapServiceLayer ID="SelectedService" />
<esri:GraphicsLayer ID="myGraphics" />
</esri:Map>
The dynamic service URL is defined in the c# code according to users' selection. The graphics are also added dynamically using the code.
I can clear the graphics in the graphiclayer, how can I clear the dynamic map service before reassigning a new url or should I redraw the whole map. Any suggestion to improve caching problems with many services to be visualized. Thanks.
DominiqueBroux
Esri Frequent Contributor
In my opinion, you have only to reassign the url.
AgatinoLa_Rosa
It is working now I am not sure what could be wrong. Thanks anyway.
One more question. The zoom functionality is working using the wheel, I don't get the pan working using the mouse. Any idea?
DominiqueBroux
This can happen if your map is inside a scroll viewer. Is it your case?
AgatinoLa_Rosa
sorry for the late reply. Yes, I have also seen another case in the forum and the scrollview is the cause. However I have added a navigator on the map so somehow I solved the problem.
Thanks
AgatinoLa_Rosa
When I started this thread I had three layers. Now users can select either a cached or dynamic layer from a list of Layers. So either one between SelectedDynamicService or SelectedCachedService would be displayed.
<esri:ArcGISDynamicMapServiceLayer ID="SelectedDynamicService" />
<esri:ArcGISTiledMapServiceLayer ID="SelectedCachedService" />
</esri:Map>
If I set the map layers as above I get problems at run time when either one url is not assigned. Is there a way I can set a generic Layer at design time and then assign a dynamic or cached url at run time?
DominiqueBroux
No way to define a generic layer at desin time.
You might consider to create the layer by code after the user selection.
