URL Extent Parameter?
6245
09-17-2013 07:42 AM
brettangel
I stumbled across a blog that discuss using xy minmax values as url parameters.  First, is this possible with Silverlight?  If so, can someone shove me in the right direction.  I assume the url would look something like this
http://blahserver/Apps/test&Extent=xMin,yMin,xMax,yMax
Brett
brettangel
Brett
That was easy.
From this
to this
http://blahserver/Apps/test/index.htm?Extent=xMin,yMin,xMax,yMax
MichaelVolz
Esteemed Contributor
Would this same technique work in a custom javascript api application?
I tried this technique but the application still zooms to the default extents of a county if I type in coordinates at the end of the url that are in a zoomed-in area of the county.  Is there any special coding needed to obtain this functionality in the javascript api?
DidarBultanov
