UniqueValueMultipleFieldsRenderer XAML Sample
2980
09-21-2012 11:54 AM
MichelleMestrovich
Does anyone have any sample code showing UniqueValueMultipleFieldsRenderer in XAML.  Not examples that I can find anywhere. I can find for UniqueValueRenderer, but not Multiple.
Thanks
Michelle
by Anonymous User
Not applicable
Original User: dbroux
I don't know any sample but it looks like UniqueValueRenderer. Just use 'Fields' instead of 'Field' and 'Values' instead of 'Value'
Something like
<esri:UniqueValueMultipleFieldsRenderer Fields="field1,field2" >
    <esri:UniqueValueMultipleFieldsRenderer.Infos>
        <esri:UniqueValueMultipleFieldsInfo Values="field1value1,field2value1" Symbol="{StaticResource symbol1}" />
        <esri:UniqueValueMultipleFieldsInfo Values="field1value2,field2value2" Symbol="{StaticResource symbol2}" />
        <esri:UniqueValueMultipleFieldsInfo Values="field1value3,field2value3" Symbol="{StaticResource symbol3}" />
    </esri:UniqueValueMultipleFieldsRenderer.Infos>
</esri:UniqueValueMultipleFieldsRenderer>
MichelleMestrovich
Here's my attempt
<esri:UniqueValueMultipleFieldsRenderer x:Key="MyUniqueValueRenderer" Fields="ParkingType,ReserveType,Interval" DefaultSymbol="MyGreenFillSymbol">
<esri:UniqueValueMultipleFieldsInfo Values="ADA,NA,90" Symbol="{StaticResource MyGreenFillSymbol}">
</esri:UniqueValueMultipleFieldsInfo>
I get the following errors for the areas in red
any thoughts.
Thanks
M
Unable to cast object of type 'Microsoft.Expression.DesignModel.DocumentModel.DocumentPrimitiveNode' to type 'Microsoft.Expression.DesignModel.DocumentModel.DocumentCompositeNode'.
by Anonymous User
Not applicable
This's a known issue in the design view of Visual Studio but should not be an issue at run time : Compile and Run should work.
