uniquevalue renderer on featurelayer with int attribute
2792
04-22-2010 03:11 AM
Bende_Vries
The samples with uniquevaluerenderer on featurelayer use an attribute of type string in the UniqueValueInfo's. I need to render on an attribute value of type int.
This example does not work for me in API version 2.0 beta:
<esri:UniqueValueRenderer x:Name="ActionLine_Renderer" Attribute="Type" DefaultSymbol="{StaticResource DefaultFillSymbol}">
                <esri:UniqueValueRenderer.Infos>
                    <esri:UniqueValueInfo Value="0" Symbol="{StaticResource Line_Rood_Dik}" />
                    <esri:UniqueValueInfo Value="1" Symbol="{StaticResource Line_Rood_Dik}" />
                    <esri:UniqueValueInfo Value="2" Symbol="{StaticResource Line_Rood_Middel}" />
                    <esri:UniqueValueInfo Value="3" Symbol="{StaticResource Line_Rood_Dun}" />
                 </esri:UniqueValueRenderer.Infos>
            </esri:UniqueValueRenderer>
On another featrelayer I use a uniquevaluerenderer based on an attribute of type string. That works fine.
Any suggestions ?
DominiqueBroux
Esri Frequent Contributor
Define the value of the renderer as Int32.
 xmlns:sys="clr-namespace:System;assembly=mscorlib"
<esri:UniqueValueInfo Symbol="{StaticResource Line_Rood_Dik}" >
 <esri:UniqueValueInfo.Value>
  <sys:Int32>0</sys:Int32>
 </esri:UniqueValueInfo.Value>
</esri:UniqueValueInfo>
  <sys:Int32>1</sys:Int32>
/Dominique
Bende_Vries
Thanks, Dominique. My renderers work fine now.
