Unable to reach REST endpoint - proxy authentication required
1160
09-09-2010 06:05 AM
PauloDuarte
I am unable to reach the ArcGIS Online's REST endpoint in Blend 4.  Getting the following response from the server:  (407) Proxy Authentication Required.
http://services.arcgisonline.com/ArcGIS/rest/services
I am, however, able to get to that same endpoint via IE 7.  Are there any proxy settings in Blend 4 that need to be configured?  I haven't been able to find anything that allows me to do this inside Blend.
Thanks in advance for any insights on this issue.
dotMorten_esri
Esri Notable Contributor
Are you on an internal network that requires a proxy configuration?
Will it work if you are outside that network?
PauloDuarte
Morten - sorry for the delay in replying.  I was out of the office.  The answer is yes to both questions.  I opened a Tech Support request (848823) and they are unable to reproduce it.  I can get to Bing Map services just fine and use the basemaps with no problems whatsoever.  I can also reach the endpoint using Internet Explorer.  This only seems to be an issue inside EB 4.
Paulo
dotMorten_esri
Sorry, I'm not aware of any way to configure Blend to use your proxy settings.
