too many polylines to load
1247
06-27-2012 12:59 PM
jamesborris
Maybe some can help me. I have a polyline layer with thousands of records and it takes a very long time to render even in arcmap. I only want this layer to show in my silverlight app when the user is zoomed in a lot. But I feel when they hit that scale its going to take forever to load the layer. What is the best way to handle this? is there a way to only render the features that are within the current extent or view. Please help if you can. and advise would help.
PreetiMaske
To display the features in current extent you would need to add your polyline layer as FeatureLayer with Mode=OnDemand.  This would query/render features that are in the current extent. But again, if you zoom out and extent grows bigger you may run into slower rendering problem. See this sample
http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#FeatureLayerOnDemand
PreetiMaske
ElieRizk
i have the same issue wit electrical lines
the layer is stored in a filegeodatabse, it loads very slow in arcmap (takes around 10 s to show up)
- i tried to recalculate the index nothing changed
- create new index again nothing changed
if i export the layer to shapefile it loads very fast (2 s) and go back to DB i face the same slowness
any solution for the above?
ElieRizk
why a shapefile become slow when displaying in arcmap after exporting to SDE?
