Tiled ma
2124
09-25-2012 08:00 AM
DeminHu
Tiled Map  service ( ArcGIS Server 10.1) display blank  in SL APP
With ArcGIS Server 10.1, I built a cached map service,  I checked the serveice properties  and viewed in ArcGIS desktop, I checked rest URL too,  I didn't see any errors, it is a completed cached map service with all titles showing up.
But in my Silverlight Application, I can only use a ArcGISDynamicMapServiceLayer, if  I use as ArcGISTiledMapServiceLayer, there is no error message, but just blank.
If somebody has clue about the problem,  please let me know.
Many thanks.
DominiqueBroux
Esri Frequent Contributor
This can happen if the Spatial reference of your map is not the same as the Spatial reference of your cached service. Happens often with a map containing 2 cached services using different SR.
Is it your case?
DeminHu
Hi, Broux
I think you are right, after read your reply, I  did some tests.
1>. If the map only have this titled map service, it can dispaly as either Dynamic or Titled map service
2>.  I created another titled map service with the same SR as my base layers, it it can dispaly as either Dynamic or Titled map service
3>. If the base layer has different SR with the tiled  map service,  the tiled map service can only  display as dynamic.
Many thanks !
